Bardstown,KY | Don, have you planted any corn yet. I planted 20ac last night mainly just getting the planter lined out. I had some trouble getting started because the planter had 2 to 1 ratio sprockets on the drive and when I planted the first 150ft and got off to check the depth there was only half the corn in the ground. Then the second round I learned that you need to change the markers back to 30in after it has been setup to run 15in rows. after I fixed all that it went pretty smooth. Takes a while to dig and know how its planting with 16 rows but the field went quick after I got it going. | |
