| Just noticed you asked for some approximate soybean settings as well, so here's a good starting point for them, depending on starting moisture, header size, plant maturity, etc.
Concave: 11
Cylinder speed: 700
Rotor speed: 800-850
Cleaning fan: maximum speed
Chaffer: 11-12
Sieve: 8-9
Disawning plates: Closed, unless beans are quite dry. You may alternatively swap the grates to a more aggressive style.
Feeder drum: Raised
Feeder speed: set according to ground speed, 380-410
