| If the dipstick is simply a press fit into the plug, it could be removed and pressed into a new plug. If it has been silver brazed, heating the old plug to dull red should soften the braze and make removal possible. It could then be pressed and spot welded or rebrazed into a new plug. Good luck finding a square drive plug as most are hex style. They know how tough it is to fix and they charge accordingly. | |
