Search Forums | Classifieds (126) | Skins | Language
Direct Command wiring on rogator
dmaxdiesel
Posted 3/21/2007 19:14 (#123345)
Subject: Direct Command wiring on rogator
Sutherland, IA
I'm wiring up a Insight and Direct Command on a 844 rogator and have ran into a problem. I pretty much have everything wired up but am having problems with the cable coming from the liquid product module that is suppose to go to the flow meter and the flow control module. I have located the flow meter and hooked it up but the flow control module is the problem. On our rogator we don't have a flow control module but we have what is know as a hydraulic control valve that i assume adjust the flow of oil to the product pump looking at how it's plumed up. There is a plug coming out of the hydraulic control valve that has 3prongs and goes into the old raven 460 wiring harness which i am removing. So i'm pretty sure i have to hook into this "hydraulic control valve" into the liquid control module but the question is how? Thanks
