lucknow,ontario | first i would to the crane boom truck anything but jacks we use your high hoe the jacks are a mean outfit and they are a lot of work your biggest worry on the move will be the very bottom of the rig whatever is sitting on the trailer you should use or make the angle iron ring from the bottom of the bin something like that to spread the load so it does not bend the sheet beacuse they are very hard to make it go back together again and i wouls keep them together if you can all you do is take about half the bolts out of the section above the joint when putting it back together and just pry it over the bottom section they are not that hard to move we took down a bunch down and moved 30 miles took the bottom apart so it could go in one trip but left the roof and two ring to be low enough we made a gin pole on the trailer so the roof was actually held off the trailer and we put planks under to keep it from twisting just dont bend the sheets and you will be ok | |
