FMX field iq as rate controller in Hagie 2100 / dts10
Noble1
Posted 6/28/2022 15:52 (#9725277 - in reply to #9725083)
Subject: RE: FMX field iq as rate controller in Hagie 2100 / dts10
Arco MN
The FMX will run the rate and section control as good as anything else out there I would say. I use this set up on several different sprayers from 30ft to 120 ft and I really like how it operates. What I don’t like is how it documents things so I went to field view drive on the system to record what I spray there for documentation.
Let us know if you need help setting anything up and we should be able to get you going
