Posted 5/14/2022 12:35 (#9660150 - in reply to #9660107) Subject: RE: Engine temperature would you be concerned.
SW OH
The bottom of the head is where I would check on the right side so it is away from the exhaust. 200 is running hot and 230 is about to melt something important. It's also helpful to compare the top to the bottom of the radiator, and the thermostat housing above and below the thermostat.
