SEQ, Australia | You can use the EZ-Boom to do that or you can possibly do serial rate control through the EZ-Guide 500 which is a paid unlock & some harnesses. I'm not too afraid of EZ-Boom's being old - they generally worked pretty well and very reliably for long periods and there are plenty still out there. My only rule was to make sure to stay at Ver 5.00 firmware on the EZ-500 as there was a glitch in 5.10 that stopped you from being able to modify the implement width if you were using it with EZ-Boom disconnected. | |
