Posted 7/31/2021 07:54 (#9139016 - in reply to #9133618) Subject: RE: Electric power for spray pumps
NW MN
So you have a strainer on the intake side of your centrifugal pump? If you do take it out, that will certainly cause a centrifugal pump to eat seals. Any time the strainer gets restricted it will reduce flow to the pump, which is also your coolant for the seal, and smoke the seal.
