Can InCommand 1200 work with two Application Rate Modules
Mostly Deere
Posted 3/13/2020 19:55 (#8102529 - in reply to #8101489)
Subject: RE: Can InCommand 1200 work with two Application Rate Modules
s.c. minn.
Not sure this is any help to you but is somewhat related. The 1200 controls my starter fertilizer, and will show rate of 32% dribble this year but since that is pumped by a John Blue there is not a good way to control rate other than change the stroke on the pump itself. The 32% flow meter however will require its own separate module to report to the console as I understand it. Pretty sure L&d Ag also told me that up to 8 (or 6 can't remember which) modules can be controlled and/or monitored at any one time. I usually just call Jimmy or Chad and they have more info than I need.
