Beaver Dam, WI | I got a hard sprayer with the triple nozzle. Sprayer nozzles started stopping I thought they were getting plugged they were not I had sprayed about 20 acres when this started. However when I would lossen the cap on the side (check valve)would start spraying again, but if I tighten the cap back to normal it would stop.took cap all the way off and there was a little junk in it cleaned it but still same result.. would it still spray if I took check valve out and capped end? ? | |
