Posted 11/26/2014 10:41 (#4202515 - in reply to #4202193) Subject: RE: No tilling with a 6 Row planter. duals on the tractor vs. duals off?
N IL
JohnG - 11/26/2014 06:58 Are those 650's? What kind of air pressure do you run to have enough load capacity in transport? Looks good!
Thanks John!
650's on the front 710's on the rear. Usually run around 20-25 psi in the back and 25 in the front. When it was on the airseeder this fall I took some weight off and ran 12 psi in the back and 18 in the front.....talk about no footprint!
