Posted 4/25/2021 14:14 (#8972323 - in reply to #8972303) Subject: RE: Deere 1790/2630, on coverage map planter not following tractor correctly after turns on endrows
In the 2630 operators manual under connecting RS 232 GPS receivers it's critical that receiver outputs are set to GGA, GSA, baud 19200, data bits 8, parity none, stop 1, flow control none, 1 or 5 Hz output rate.
