Search Forums | Classifieds (22) | Skins | Language
Poly cup auger
grains-n-corn
Posted 2/23/2021 10:13 (#8852832)
Subject: Poly cup auger
Bought a used air cart and drill, Deere, has a auger setup on it instead of a belt, mainly because it came from small grain country,
I was wondering if its worth while putting a poly cup auger in to reduce damage to soybean seed, or is the steel flighting fine if ran properly?
Also is the poly auger safe to use on fertilizer during winter wheat seeding? Only planning on putting 40ton of MAP through it a year at most.
TIA
