| Im told that Norac UC7 will run on several different displays using the ISO. We have a Norac UC5 setup and are looking at trying to run it using ISO on a Deere gen 4 display. I am told this should work but not an absolute yet to this point. I was also told by a good Raven rep that Norac through the ISO is a big pain. Sounds like if you have norac trouble it can shut you down spraying until the issue is fixed. Im guessing it does this by contantly popping up on the screen until fixed? If anyone has any experience here it would be appreciated. | |
