Floyd County, Iowa | Dirtfarmer1000 - 1/24/2021 13:13
You will be better spending your money on an ez steer. No need for a bar. Not sure if a 250 has lights on the screen, but if not upgrade to a 500. Trying to watch a bar and spraying is mind numbing. Using an Ez 500, ezboom and easy steer spraying would pay for itself the first year if you spray any sort of acres. Probably figure 10 percent overlap on a hundred acres at 30 bucks an acre. Adds up pretty fast. Buy a used system. Half the price of new and works the same.
Correct me if I'm wrong here. I have an EZ Guide 250 and EZ Steer 500. The EZ Guide 250 is the lightbar, and the EZ Steer will not run without the lightbar. Something has tell the EZ Steer where to go. |
