Posted 4/18/2009 22:18 (#685056) Subject: How tight are your sway blocks/planter
South-central Nebraska
I've got my first pull type planter, do you run the three point tight with sway blocks or leave loose? The manual doesn't really say. I could add shims but I don't know if it is necessary. Only time I know there is slack is when I back up and the hitch is allowed to swing a bit. I probably have an inch or so on each side. Where do you want this?
