| I have a NH T5-115. It is not a comfortable or quiet as the larger T6 tractors, but very reliable and the 4 banger pulls my 1000 gallon sprayer with no problems. Make sure you get the 24 speed or powershift as the standard shuttle shift tranny does not have a wet clutch. In 1800 hours, only an o-ring on the hydraulic pump blew out (they now use a square o ring) and a shift cable needed replaced do to the crimp holding the end on came loose. Easily handles 1800 lb bales with the factory loader. Starts very well in cold weather too. | |
