Posted 12/1/2020 06:20 (#8636826 - in reply to #8635024) Subject: RE: Dump trailer
SW Ohio
I built this last winter. Did not cut the frame rails any shorter, though I maybe should have looking back. Use the tractor PTO to drive the pump on the truck and a cable to actuate the control valve. Works great! It was the simplest solution at the time for me. If the truck hyds had been junk I probably would have just used the tractor hyds.
