| No, loads true up only calibrates the current and future fields and should only be done after the initial, main calibration. To apply a calibration to everything you need to reset the crop constant by going into setup, systems, crops, selecting the crop, and pressing reset on the right hand side. Then come back to your main screen and the calibration box will be in the lower lefthand corner. Press start, harvest a load of at least 25k and then enter in the actual weight. Reference the manual for more detail. | |
