West Tennessee | So many things interact on these machines. I would definitely fix the speed issue then see where you are on the autotrak. We had an issue with the forward reverse sensor on our 9770 and it definitely screwed with the autotrak big time. Hope you figure it out.
Edit to add: Much more likely to be a bad connection than a broken wire from my experience. Plugging and unplugging connections has fixed WAY more issues than I can count. Knowing or finding which one to mess with is the challenge. We fixed an issue that was 6 years old by plugging and unplugging connectors this year. I just knew it was a bad RCU.
Edited by BHTN 9/30/2020 05:49
