| I have an Integra set up with a 1500 globe. I just purchased a 6000 globe that I want to use on the tractor and leave the 1500 on the combine. Can I set both of these up on the same Integra monitor and just switch the monitor between equipment? Ag Leader says I need to do a setup procedure for the 6000 to work. Will this delete the 1500 settings?
Thanks.
Details How to Configure- Go to GPS Information > View Messages
- InCommand - Go to Status Indicator (top right button) > GNSS > View Messages
- Integra/Versa/Compass - Go to GPS Information (top left button) > View Messages
- Press command window keyboard > type "unlogall com1" > green check > Send : This will clear out any commands foreground or background that may be turned on on port A. Then return to the Home Screen
- Press the double ended wrench (Setup).
- Then select the GPS/Guidance Setup” icon
- From GPS/Guidance Setup page, select the receiver wrench icon. The GPS settings page will now populate. This will show that Port B is the “Connected” port.
- Uncheck NMEA Talker if it is enables
- Select the Port A tab and adjust baud rate, NMEA strings, and Hz rate for use with the appropriate display
- Edge and Insight – 38400 baud rate, GGA(Legacy), VTG, and set to 5hz rate.
- PF series and YM monitors – 4800 baud rate, GGA(Legacy), VTG, and set to 1hz rate.
Important Note: You will not be able to change the baud rate below 38400 if 10 Hz is selected. To achieve a lower baud rate, first adjust the Hz rate as required by the legacy display.
- Once Port A is configured, disconnect Port B from the InCommand or Integra/Versa/Compass display. The receiver is now ready for use with Legacy display.
