Central IA | I'll try, not in front of combine or manual.
Right side of feeder house. Belt, go to bigger front pulley, smaller rear pulley. I did not adjust the feeder drum height from corn.
Rotor goes to high, If beans are dry, stems and all. Shell very good at corn setting(concave), I had to close if green stems.
Chopper, can't remember if R40 I had had a high and low setting, engage knives if you like. Spreader I think goes to high in beans(not sure).
I had a corn and a bean chaffer(top seive) changed that too.
I only had a 15' bean head, fed like crap in short beans. Very good in tall beans. The feeder house was the limiting factor. I had hydraulic reverser. Mine had a R50 engine, turbo. So never worked hard at all. And could go almost 2 days on fuel with that Duetz.
Total memory, hope I helped. | |
