Search Forums | Classifieds (2) | Skins | Language
Pro 600 to Raven 440 Layer Assignments
Rod!
Posted 4/5/2009 17:29 (#669840)
Subject: Pro 600 to Raven 440 Layer Assignments
NW IL
Help! When I go to the Pro 600 and go to Work Condition - Layer. I select a new Layer name I should get something to pop up like B:Raven - 1. All I get is the no control option. Without this I can not get a product associated with the Layer and with no Layer I can not get anything to work. The two are communicating and I believe are interfaced together correctly. Most likely it is a simple go to the right screen and select this however I have not stumbled onto what it is yet. The way the instructions read the B:Raven - 1 should just be an option to select from since that is what port it is hooked to. There was only one port choice on the bottom of the Pro 600. It is only several months old and all the software has been updated within the last week. Since no product has been assigned to a layer yet the Pro 600 keeps changing the rate 1 in the 440 to zero.
Any ideas?
