Posted 8/6/2020 13:58 (#8418955 - in reply to #8418377) Subject: RE: Floor for squeeze chute
The Palouse North Idaho
Yyou could use wood and then add steel strip screwed to the floor for traction. There is also some stuff called Rumber which is a rubber coated wood product that is used for trailer floors and decks. Or, stall pads cut to the correct width over your steel floor with steel strips screwed in for traction.
