Near Intersection of I-35 & I-90 Southern Mn. | Dawson is correct at least with a Nav II so I would expect that to be the same for a Nav III. The Trimble Navs want to communicate using TSIP (Trimble Standard Interface Protocol). Since the Ag Leader can not produce TSIP only NEMA, I don't believe this will work.
Doing things the other way around may work. Since a Trimble GPS can output TSIP messages, NEMA messages or Both they can be used as the GPS source for some other brands but not all or every situation.. |
