roaming | Eric from Canada - 7/22/2020 17:37
I’m trying to help a friend get an On/Off variable rate script to run on a Pro 700. Case Sprayer, CNH Product Controller II. Currently the boom shuts of sections when it travels outside on the field boundaries, but keeps spraying the 0 gal/ac rate zones. I’ve though about modifying the field boundaries so that the boundary would just include the 30 gal/ac zone, but I’m not sure how I would go about doing that. Also, I don’t want to mess up the boundary for autosteer in the combine.
Has anyone on here had any success running an On/Off variable rate script in a Case or New Holland with a Pro 700 or Intelliview 4?
Not sure what's causing your issue, but I can confirm that your autoguidance doesn't care about your boundaries, so you could modify your boundaries as a workaround to solve your issue, without impacting guidance behavior. |
