Posted 4/3/2009 16:18 (#667731 - in reply to #666262) Subject: Re: Mr SID overhead imaging question
D,
Sids are already Geo Referenced........say you want a section, 640 acres.......you need to go in and select an area a little larger that encompasses the entire sction you want and then save and import........
I use SUMMIT and have to use a Lizard Tech wash od the Mr Sid files but it should be similar to what you are wnating to do........
When is spring coming? We will be cussing the heat soon, guarantee it!!
