Eastern Nebraska | Had a buddy with a custom build trailer that wanted to do the same to it. If your axles still have the tags on them you can looked the axles up to see if you can convert it or not. His axles were old enough the newer parts wouldn't work. He ended up buying new axles with the disk brakes already on them and even went to a full air brake system and did away with the air over hyd system. I don't remember what the axles cost but it wasn't cheap but he needed a whole new drum set up any way for his axles. He has had good luck with the disc. | |
