Posted 6/24/2020 09:59 (#8333330 - in reply to #8333235) Subject: RE: Hot wire around perimeter, 160 acres
The Palouse North Idaho
I use 12 gauge high tensile wire. It has low resistance and doesn't deteriorate like poly wire. You'll need a good fence charger and make sure you have a good ground system. Put some switches in the line to isolate for trouble shooting.
