| Have had this happen to me and three other guys all with accuguide systems running with pro 600 on v 21. 252 versions vary. Two were on RTK and I can't remember the other two. Sometimes when you start the tractor. Can't get gps so you look in toolbox and under gps and you can't pick your correction. The only option is autonomous. Most of the time if you turn the tractor off and on it fixes it. I've let case know but I've had good luck with things getting resolved quicker when the problem becomes public. Just wondering if anyone has seen this or if you have this system look/check and see if it happens to you. Not a huge problem but I'm sure its an easy fix once the right people become aware of it. Thanks. | |
