Butterfield, MN | Generally if you have adjusted the online sensitivity and can't get this to go away, you could try adjusting your PWM minimum values up a little bit if it feels too lazy, and down a little bit if it's a constant swerve, since any steering motion it's making is too powerful. Also, is this a steer-ready unit with the Case valve mounted behind the cab, or does it have the Raven valve mounted up by the radar? There's a kit to add on a wheel angle sensor for the steer-ready sprayers due to the steering performance not being quite as good. | |
