nw pa | 10 foot pull behind is lot of blade for that tractor ,no way it.s going to pull it through any kind of hard dirt. You need weight and lots of it.. no loader attached.. Next thing is experience. You may be only able to take and inch of dirt with that set-up. It takes some practice to know when not to go deeper and when to lift it up.. Until you get the hang of it the depth stops on cylinder is good idea. Should be able to go light and feel the load and when it's going to slip.. if your working in mud.. It won't work at all.. You'll be stuck all the time.. the outfit you have is good for light grading of a driveway ,but not suitable for much dirt work.
Just what are you trying to do? Pictures? | |
