Search Forums | Classifieds (227) | Skins | Language
Ag Leader Water Management Module not working
Papa Gene
Posted 5/18/2020 17:26 (#8265392)
Subject: Ag Leader Water Management Module not working
SE SD
Ag Leader Water Management Module is dead. The LEDs on the unit stay dark. There is power at the 12 volt connector plug on the module. If the power LED doesn't light up and there is power, is this for sure an issue with the module or could there be an issue with the other wiring harness or setup in the Integra?
Everything worked last fall when I put it away in the shed. Just hooked back up and the Water Management Module was not found. I checked over all of the wiring for rodent damage or other issues. It all looks OK.
