| I bought a second injector to run with the sprayer and I can't seem to figure out how to configure 2 sidekicks to run together.
Going through the config screens it seems I can pick either the new injector or the old one. But I can't add both the the configuration. Its an Agleader Integra and has multi-product which would be required for the first injector. Once I select the first direct injection. It greys out the button to add a second..... The modules are there. I can seem them. I even reloaded the firmware on it to be sure it was alive.
Does Agleader limit you to one injector module with each direct command? That would be silly. But that is what it seems.
