ne ia | my 310E was doing that last fall, found out differential was low on oil. didn't have operators manual , so I called jd mechanic. need to check oil on dipstick just inside sliding door on right side, to the left of engine oil dipstick. learn something everyday. also said check connections on brake solenoid? on to of rear end? don't remember all the details but added oil and light went out. always figured hyd oil level was measured in little sight glass/tube in front of cab, right by door. didn't realize diff. was seperate. | |
