| I was wondering if you could give me some more information on what pin in the 7 pin was causing you trouble. I am having a similar issue. My compressor will run sometimes and other not but have voltage at compressor coil. Have by chance found that disconnecting the connector for the 7 pin on the right side pull bar in front of the row units that I can get the compressor to again for awhile. Was hoping you could tell me exactly what pin I should be tracking down. | |
