Near Intersection of I-35 & I-90 Southern Mn. | I didn't do many but I believe the above is true that the switch can be either Normally Open or Normally Closed as a menu setting allows you to choose one or the other. This is in contrast to implement switches with Ag Leader Clutch modules which must be closed when application is desired.
Edited by tedbear 3/23/2020 14:32
