Posted 6/19/2019 07:56 (#7567988 - in reply to #7567908) Subject: RE: PTO
ESW ND
You may also consider replacing the balls and spring inside. On some older stuff we have, the collar wouldn't go back all the way, even though is seemed it was. That wouldn't allow the balls to go into the specified spot to allow the shaft to go in. So, check your balls and lube your shaft. Words to live by.
