Sibley County, MN | I am running an Ag Leader InCommand 1200, and a 6500 globe with steer command in my Challenger MT665D tractor. I am using RTK correction running in strip till. The tractor has an integrated steering valve. Every once an a while, the system will be 9" off course and will not correct its path until I disengage the auto steer, then reengage it to get back on course. I noticed this last spring as well, but after updates to the steer command and the incommand, it is still is doing this. I'll contact my tech support again about this on monday, but has anyone else had an issue like this on a Challenger or any other color? I understand that there is an updated steering valve (PVED) available from Agco, but it is not cheap, and will it solve this issue???? Just trying to figure out if it is an Ag Leader issue, or a tractor issue.
Edited by ks55336 5/18/2019 11:01
