Deep southern Illinois | PUNISHERVETTE - 5/18/2019 07:41
I have another issue where every turn it lines me up 6inches wide and slowly(over 100+ft) straightens out. Making every pass look like I can't turn correctly.
Is your implement also tracking 6” off, or just your tractor? If implement is tracking off, I’d double check the measurements in your implement configuration to make sure they’re not a few inches off (hitch to application point makes a major difference on curves) you might also go into your settings for your steering (speaking as a steer command user) and increase the number for your “line acquisition” by one. This will either fix your problem, or it will start to “Hunt” for the line too hard and overcorrect, in which case you should adjust it back down until the issue is resolved. |
