NW KS | There should be some basic settings that you can change through the menus on the insight. The steering for this system is handled by NavII controller. NavII controllers can be calibrated with autopilot toolbox on a laptop. It is a fairly simple process to calibrate with autopilot toolbox but don't change any of the more advanced settings. Anyone the works with Case/ih, New Holland, or trimble systems should be able to help you out. Just tell them you need the NavII controller calibrated. The NavII controller settings are all the same only the display is different. The Trimble monitor that you are thinking of is the FMD and searching for information on settings for an FMD may be helpful. | |
