Near Intersection of I-35 & I-90 Southern Mn. | I wouldn't bother with the pressure plan. Pressure gauges are just a reference point in my experience. I remember when I first started as a sprayer tech. We had a customer who purchased a new 6 section sprayer and he wanted a gauge on every section and wanted them to read the same. We tested his new sprayer with water at the shop. We had to swap out several pressure gauges to finally get a set of 6 that read the same.
I would change the meter cal as suggested above. Otherwise don't change anything and each time you make a 1000 gallon batch which should cover 100 acres but covers 104, put in the chemical for 104 acres.
Edited by tedbear 4/30/2019 07:20
