North Dakota | Looks like flat rate is around 45-50 hours. That would mean that it could be done by someone that has lots of experience with all the correct tools and stands in around 70 hours. Flat rate is what they will pay when the unit is under warranty. Cab removal takes about 2 hours with the correct lifting rig, half a dozen connectors and four cab mounts lifting arrangement bolts to the side posts of the cab.
I would first question why you believe it is the park brake that has failed. I don't think I have ever seen a park brake fail. | |
