WC Mn/Dakotas | Converting, Calculating, and building recs are the parts of the process my fertily specialist does. You could blend, but I dont think you really should. You absolutely do not want to put on any lime areas that are in the 7s ph. Separate bin or separate pass
It needs to be incorporated and time for chemistry to raise ph. Then after that the chemistry is more capable of allowing more plant available nutrients. Roots are not attracted to fertility, they grow in the presence of available nutrition. Big difference. | |
