| You cannot adjust the rate being off a couple of pounds. The Accuplant can only change rates in a 2.66% for seed and 6.66% for fertilizer. increase or decrease from its starting nominal rate. So if you set the nominal rate in the controller for 130 and the pf3000 is sending a rate of 150. The Accuplant with every click of the nob adust the rate 3.5 pounds which is 2.66% or 8# for a 6.66%. So sometime it will match but if it is off a few pounds that is the best you will ever get. I hope this helps on the rates not matching up.
I thought the accuplant only controlled seed and when you went to the accurate it would controll fert as well as seed. | |
