N Central IA | I would suggest putting the antenna out in front of the hood instead of on top of the cab. I have an 8960 with antenna on the cab and it works great, but my 9220 had to put out in front of the hood to make it work the best. As far as accuracy it should be the same as your other tractor, an S-2 has about 8inch accuracy at its worst and about 5 in most of the time from my experience. All you need to purchase is the hydraulic kit from Out Back for 8770 which is around $1000 and you are set.
Edited by tileplow 2/7/2009 17:15
