Posted 2/16/2019 10:44 (#7324220 - in reply to #7324166) Subject: RE: Hot 30 amp fuse
Swaledale, IA
Did it blow the fuse the first time or else why did you unscrew it? If it was left a little loose that could cause problem. If box looks good there is no need to believe that it should be replaced unless you just like flipping breakers instead of screw type fuses, which is OK also.
