Posted 2/5/2019 06:09 (#7297813 - in reply to #7297450) Subject: RE: Liquid on Kinze planter
ncia
I will disagree with boone on "the easiest and most accurate" . I use a ground drive piston pump. Ive had them on 3 planters and very very accurate. I cant think of any issues. Plant about 800 acres of corn per year. check out L&D ag website. Only down side is if you don't want fertilizer, you have to take off a roller chain. cant switch off and run dry.
