Posted 1/11/2019 06:25 (#7236640 - in reply to #7236619) Subject: RE: Krone big square baler with rotor cutter
Northwest iowa
I think the cutting systems are similar, but that’s where the similarity ends. Krones pre-chamber system is far superior to any other manufacturer especially in wet feed. The vfs as its called has a lot more capacity and can be pushed to its max without fear of plugging as it can unplug itself. If it plugs you just stop and pull the throttle back and it will clear itself.
